I look for your oppinion guys. I have mounted a sender unit to control my electric fan a while ago. I choosed a model from a toyota because i liked the small shape (M16 x 1,5) and the temp seemed to fit my needs. It was supposed to have 92 C- 85 C (197 F- 185 F) i am so bored out now because it will not be accurate.
The first i tried did not give signal until the water boiled, and stopped very soon (short signal to fan)
So i tested it in water with a temp sensor. It gave signal at 101 C - 97 C (213F- 206F) I bought another one, and it was nearly the same... These two was supposed to have the signal area about 95-88 C (203-190F)
I got a bit depressed since i already had welded in a nut in the radiator, but found the sensor with a bit lower range, i tried 3(!) and the best gave signal at 97 and dropped signal at 90 (206-194F) I am using this sensor for the moment. My plan was to get a overflow tank to my radiator, but for the moment i have a 16psi cap. But still i feel this is to close to boiling point...
What can you guys suggest? Will this be safe? The fan is really realible/ effective. I thought maybe this sensor will due if i get a overflow tank, because that should do that the water do not boil at 100C (212F) but if i do not, is it enough to have the 16psi cap...?
Or should i try to install another sensor with more accuracy, and weld another nut if necessary... (please not)
(I have placed the sensor near the top of the radiator because of the range the sensor is supposed to have)
But the sensors are tested in water indoors before i ever mounted them. So trust my numbers...
It went wrong.. here you go:
