rtse4406pack wrote::D when mixing water to your antifreeze use disteled water. it is fairly cheap and it is a lot better than tap water as it is pure with no crap in it.
.gif)
Pretty Sneaky there Barc, did you at one time make a clear liquid derived from corn sqeezinsfal308 wrote:One tip to get free distilled water is to capture the condensate from your home air conditioning unit, if you can.
In the house I used to live in, the AC drained through a hose into a drain in the basement. I just had the hose drain into a clean gallon jug.
Seriously, I never thought about that, and with distilled water costing 70 cents a gallon it adds up. I use approx two gallons a day in my home. Coffee and my Earl Grey every morn and eve. it's a ritual thing.
Is it in yet Wayne?RedRaven wrote:Guys what coolant do you recommend and what mix 40/60?
Will tap water suffice and how much liquid will she need of both?
Thanks
Red.
.gif)
Waittill Dave sees this!
airfuelEddie wrote:As I asked previously, the tune up, when was it done last? Yeah, it could be the pump Wayne, it could be the gunk sloshing around inside your tank,( if it's the original tank and pickup tube), could be the sock plugged at the end of the 5/16" pick up tube located inside your fuel tank. Does it run at all? You do have a working fuel gauge and it's got plenty of fuel inside the tank right? Just trying to eliminate the obvious and not being dis-respectful Wayne
dave-r wrote:Ok. The empty transparent thing is probablt your fuel filter.
As you suspect it should be full of fuel. Or at the very least 2/3rds full.
So. Where is the filter?
They are usually (quite correctly) placed between the fuel pump and the engine. However that means that the problem is going to be anywhere between there and the tank.
So. The likely possible problems (working from the filter back) are;
1) Bad fuel pump. If it is the original 40 year old one in particular. Not sure.
2) Heat. A fuel line near the exhaust pipes or exhaust gas blowing from an exhaust leak can vapourise the fuel in the line. Whats the solution to this?
3) Blocked fuel line. Whats the solution to this?
4) Blocked vent in the fuel tank causing sucktion from the tank. How do I unblock this?
5) No fuel in the tank. (Indicating half full)
Out of those I would say that #1 and #5 are the most likely.
