LOW temp on SB
I have strange problem with my 318. With original radiator engine was overheating, i have installed 26 inch aluminium radiator and Derale 19 inch fan. The termostat is 180 deg, new one and also HD water pump.
Now the engine reaches teh desired temp at the idle but when i start to drive it temp drops to around 55-60 deg C (131 - 140 F) and stays at this level when i drive outside of city with steady speed, even in the city temp is going down as soon as i start to drive.
I am using very nice billet specialities waterneck (no leaks anymore) but i have found that termostat is moving inside it, when i take our the water hose i can lift it like 1-2 mm. Maybe thats the reason? I ma confused and do not know what to do. Mazbe i should switch to electric fans.
Any suggestion will be highly appreciable.
