by spitfire9137 » 10 Aug 2006 10:40
By a mechanical temp sender, he means, there is a sender that goes into the port on the water pump housing, then there is a tube running to the gauge. Autometer sells mechanical temp gauges that work that way, im not sure how the sender works, or if you have to fill the tube with anything.
Maybe your tubing has a leak in it, or the sender or gauge is bad.
