Cooling system improvements
While my tranny is out I have easy opportunity to upgrade my cooling system. The Mopar cooling systems are said to be not too efficient. I have a 26” 3 row radiator, but capacity (the “Max Cool system”) on hot days above about 25 centergrade (77 Fahrenheit) is not enough. Getting in a traffic jam after an hour driving at 120kmh (75mph) leads to a watertemp meter indicating about 70 percent (original meter). This may also occur without the highway part, if it is hotter. An immediate stop at a gas station may imply 3 quarters of a liter (about 1 and a half a pint, be it imperial or united) of cooling liquid being thrown out.
Oh by the way, she is drinking LPG these days, not gasoline. LPG burns hotter.
Measurements:
(the “canals” in the engine are allready cleaned)
-My radiator is being cleaned, meaning airflow and waterflow is taken care of. I consider the radiator suspect #1.
-A transmission cooler of maximum dimensions is being mounted. This should restrict the thermal energy dissipation (?) of the ATF element in the radiator.
I have a 18” flex fan mounted, the original fan is 19”. (A flex fans are fans that are supposed to save a couple of horses by flattening out at high rpm to reduce drag, save weight and save the waterpump bearing too. Available from 12” to 19” in increments of 1). There is no shroud.
I am considering to find a shroud and mount it.
Thermostat has to be checked, I forgot whether the last owner did that or not.
There seem to be certain “air leading” rubber or steel parts available, that close the gap in the front valance panel and between the radiator grille and the small beam/strip the radiator top is close to. I don’t have them.
Any comments? Do I need the shroud? Will it be of use considering the one inch smaller than original flex fan? Do I need those “airconductors”?
What about those aftermarket high volume low weight waterpumps? And the “Flow Kooler water pump conversion disc” claiming 60% increase of flow for $5.95?
I think coolin science in general is not widely spread, so this is trial and error country I am afraid. Any experience considering an upgrade of the cooling system for my 383 is appreciated.
Measurements:
