Fender Tag Decoding
Postby GibDTD » 16 Oct 2011 20:25
As it appears on the fender tag
V5X L2 458
J25 L31 M21 M26 N76 R11
KB5 U 541 C56 G11 G54
KB5 A6B6 000 C05 092051
E44 D34 JH23 G43 242186
I know little outside of the Blue/Blue color scheme, 318 w/auto transmission, and lights package. All input or comments are appreciated.
GibDTD
Board Regular
Re: Fender Tag Decoding
Postby fbernard » 17 Oct 2011 11:34
You should post a picture of the tag, and maybe try to make a pencil impression of it on paper, you have some digits off (the VIN has to be JH23G4B, not JH23G43, and the end with L2 458 is wrong too, there wan't be an "L" there, but I can't guess what should be there. Options are listed alphabetically, so it should either be a W or Y option, or the "26" which indicates a 26" radiator, which usually comes last)
You can do it yourself also, there for example : http://www.mymopar.com/index.php?pid=87
Just fill in the numbers in the same spots as they appear on your tag, and click Decode.
Here's what can be decoded :
E44: 318 cid 2 barrel V8 230hp
D34: Light Duty Automatic Transmission
KB5: Lucerne Blue Poly Exterior Color
A6B6: Trim - Basic, Vinyl Bucket Seats, Blue
000: Full Door Panels
C05: Build Date: December 05
092051: Order number
KB5: Lucerne Blue Poly Top Color
U: USA Specifications
541: Unknown -probably B41, front disc brakes with 10" rear drums-
C56: Bucket Seats
G11: Tinted Glass (all)
G54: Outside LH Remote Chrome Racing Mirror
J25: 3 Speed Wipers
L31: Hood/Fender Mounted Turn Signals
M21: Roof drip rail moldings
M26: Wheel Lip Moldings
N76: Coolant Recovery System
R11: Radio Solid State AM (2 Watts)
V5X: Body Side Stripes, Black
L2: Unknown
458: Unknown
fbernard
Postby Culvers » 17 Oct 2011 16:49
fbernard wrote:E44: 318 cid 2 barrel V8 230hp
541: Unknown -probably B41, front disc brakes with 10" rear drums-should be B41
C56: Bucket Seats
J25: 3 Speed Wipers
L2: Unknown End of Fender Tag Codes, Line 2 build
458: Unknown I think nobody knows
Culvers
Board Regular
Postby Alaskan_TA » 18 Oct 2011 1:44
It was the Scheduled Production Date actually, most online decoders have this wrong.
Since it is a 1973 model, if the original Mylar sticker is still presesnt on the driver's side door near the latch, what does the MDH code say?
Alaskan_TA
Postby Alaskan_TA » 18 Oct 2011 1:52
Body side molding actually, see http://www.hamtramck-historical.com/ima ... er0004.jpg
Alaskan_TA
Postby GibDTD » 19 Oct 2011 15:58
The sticker is still there to my amazement, buy its covered in some black crud so ill try and clean it up today and post a picture of it. As for the VIN on the fender tag, I knew something didn't seem right when I typed it in. To save space in the garage someone set the hood on without the hinges so its a bit of a pain to get to the tag now. The car does have disc up front and drum in the rear so B41 would be correct.
GibDTD
Board Regular
Postby burdar » 19 Oct 2011 20:17
A57 isn't on the tag so it doesn't have the Rallye package. J54 is also not on the tag so the car came with the flat hood.
burdar
Postby GibDTD » 19 Oct 2011 22:41
Heres a picture of the tag on the door. I didn't get all the black paint off, but the tape (crud) came off easily and quickly. Are there any other items like this around the car that can give more history into the vehicle?
Door tag. I love the blue showing around the tag, the car is staying that color. :-)
GibDTD
Board Regular
Postby GibDTD » 19 Oct 2011 22:45
burdar wrote:54 is also not on the tag so the car came with the flat hood.
I feel that if it doesn't have a bulge, its not a challenger. The bulge pulls the whole appearance together.
GibDTD
Board Regular
Postby Alaskan_TA » 20 Oct 2011 1:36
MDH 12 05 23;
12th month (December 1973, 1974 model year) 5th day, 23rd hour.
So, in this case this car was actually built on it's schedlued production date, but it is not always the case. Just one hour later would have pushed it into the 6th......
You can also check the car for broadcast sheets. For a '74, check behind the glove box insert, under the front seat bottoms in the springs, in the rear seat bottom & back in the springs & under the carpet.
If no one has searched it before you may find one in each spot.
Alaskan_TA
Postby GibDTD » 20 Oct 2011 23:33
Just checked, there's nothing taped to the glove box, under/in the front seats, or back seats. I haven't checked yet, but I don't think there's anything under the speaker panel behind the rear seat. There was no carpet in the car when I bought it so there was none there. Someone beat me to all of them... :-(
...At least I have a fender tag and a VIN to accompany my Challenger.
GibDTD
Board Regular
