I guess I'm a little surprised you haven't seen a font like mine christer & eddie.  They are on their fair share of LA built cars.
My tag is bent a little more than usual in the upper left hand corner from when it was bent up at the factory for paint.  The tag's not completely flat which gives it an optical illusion of being offset.  If you want, print it out and measure the distance between the screws and the bend of the inner fender.  It's the same cause I tried it.
  The tag has inspector stamps on it as well.  Something Backeast or anyone else doesn't replicate.
The screw's were NOT both painted the same color.  The factory bent the tag up vertical with the left screw holding it down for paint.  The second screw then attached the other side down, hence the screw not being painted.
I appreciate you guys' concern but I'm 99.999% sure my tag's authentic.
Now back to my original question.  There must be a date when the LA factory standardized their fonts?  One thing with the pix I posted is my car is a December built car and the other is October which is more intrigue.  Maybe they used a separate stamp system?
