R/T Rick wrote:The distributor pad has "S 440" then under that "6  25    2" and nothing on the oil pan rail.
Usually there are either one or two digits before the displacement stamped on the id pad at the front of the engine.
S 440 is odd. One digit like that is usually the year code. But if it was this would be a 1962 engine!
However if they had a stock of warrenty engines would they stamp a year code?
So assuming this is actually the second digit then "S" will be for "Special" and warrenty engines were stamped like that according to my books.
"6-25-2" will usually mean 2nd engine built June 25th But what year?
