 by Jack T » 21 Oct 2001 0:29
			Lenny,
26 CN1
H42 N85 R11 V9X Y05
G33 N51 M22 M25 M31 N41
V1X A01 A62 A63 A66 B51
FY4 H4X9 000 B13 Q24827
B55 D32 JH23HOB 189861
J - Dodge Challenger
H - High price class
23- 2-door hardtop
H - 340 4-barrel high performance V-8
0 - zero, not letter O, 1970 model year
B - Assembled at Dodge Main in Hamtramck Michigan
189861 - series number
B55 - should be E55 in that position for the engine type, a 275 HP 340 4-barrel
D32 - 727 3-speed automatic transmission
FY4 - Citron Mist metallic, a 1970-only color
H4X9 - H, high trim grade; 4, split bench vinyl seat; X9, black interior trim color.
000 - Full door panels
B13 - assembled on November 13, 1969
Q24827 - Dealer order number
V1X - Full vinyl roof, black
A01 - Light package; Glove box lock, Map/courtesy lamp, Reading and dome lamp, Ash receiver lamp, Cargo compartment lamp, Trunk compartment lamp, Hood or fender turn signal lights (N/A with sport hood in 1970) Raer dome lamp switch, Ignition switch lamp with timer, Headlamp on buzzer, Headlamp switch with timer.
A62 - Rallye instrument cluster
A63 - Challenger moulding group; body belt mouldings, Front stone shield (valence) mouldings (two-piece in 1970) Hood rear and fender mouldings, Rear Astrotone-painted aplique, standard on the SE
A66 - 340 preformance package; 340 4-bbl engine, 11" HD drum brakes, F70 x 14" Goodyear Polyglas raised white letter tires, Rallye suspension, Transverse paint stripe, "Scat-Pack" decal on rear quarter windows, 26" radiator diameter and the standard wheel lip moulding is deleted.
B51 - Power brakes
G33 - LH outside chrome remote control racing mirror
N51 - should be H51 "Air conditioning with front heater" in this position on the tag
M22 - Could this be M21 "Drip rail mouldings"? It would be standard with the vinyl roof. There is no M22 code in my book
M25 - Body sill mouldings
M31 - Body belt mouldings
N41 - Dual exhaust system
H42 - should be N42 "Bright exhaust tips" in this tag position
N85 - Tachometer
R11 - 2-watt AM Musicmaster radio
V9X - Transverse "Bumblebee" stripe, black
Y05 - Built to USA specs
26 - 26" radiator diameter
CN1 - should be EN1 "End of sales codes assmbly line 1" in this tag position
Nice car with a good set of options!
