Y39 in tag code ? anyone else ?
22 Dec 2004 20:49
by HemiRat
HI !
Have a Y39 in my tagcode ( 71 challenger RT , swiss schinznach car )
Have asked in US and here... Nobody knows what it means exactly.
I know it means special order, but what is special ordered ?
Does anyone else has this code ?
Its in the 2e tag in this set up line :
R26 radio cassete V68 delete stripes
Y39 = special order 26 =inch radiator EN2 = end of second shift build
Well anyone ??
Thanks in advance !
22 Dec 2004 21:23
We have discussed the Y39 code once before (
http://challenger.mpoli.fi/phpbb/viewto ... ?p=459#459 ), but we didn´t manage to solve the mystery then....
We´ll give it another try then
How about posting the complete fender tag info? It may give some clues....
24 Dec 2004 22:24
Y - Exterior Dressup Codes
(According to
http://www.cudaworld.com/fendertags/y.htm )
All 300-H's had code Y39 listed on their data plates and broadcast sheets, which indicated the presence of the "Special Order" paint/decal scheme and body panel components.
(According to:
http://www.saskmoparclub.ca/ddsummer2002.html )
I think this information give us hint of what the Y39-code stands for.
25 Dec 2004 12:49
by moparmaniac (owner4)
Not sure, but I wonder if Y39 has something to do with the exported cars with high impact stripe packages. Such as a Panther Pink Challenger with a flourescent pink stripe. I've seen a few other combos and these were only available on export cars.
01 Jan 2005 0:15
by JackT
Y39 may apply to exported cars because of the destination country's requirements, but I have a Y39 car that was first sold in California, my R/T SE. The paint code on it is 999 because it was ordered with a Chrysler Imperial-only color, A9 Charcoal Iridescent and in order for it to be painted that color, it had to have been special ordered according to the MOPAR paint chip sheet from 1970. My opinion is that Y39 was applied to anything that was outside the bounds of the standard order sheet at the dealer.
01 Jan 2005 9:59
I found this car on ebay. Maybe it can give us some additional information.
1971 Dodge Challenger Convertible Y39 special order, two fender tag, special order code 999 paint code car.
This car came factory with the following fender tag code # N42 M44 M91 R11 V7W CTD L25 L31 M25 M28 M31 C55 G15 G31 G33 H51 J41 V3W U A01 A46 B51 C16 999 H6XW 000 315 K45010 E44 D31 JH27G1B .
TAG #2 Y39 26 EN2.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... egory=6198
02 Jan 2005 18:44
by JackT
My R/T SE also came with the code Y14, "sold car", and a friend of mine has a 1969 Road Runner with 999 and Y39 that was painted some kind of special orange color. I can't remember the color's name, sorry.
02 Jan 2005 21:46
Where do you find the colour-code on a Y39/999 car? On the broadcast sheet? (I presume you don´t find it on the fender tag!?)
02 Jan 2005 22:26
by JackT
Special order paint also had it's very own code, V09, but the color code does not appear anywhere on the fender tag for a 999 car. I feel safe in assuming the color would have to be noted on a build sheet somewhere, but cannot say for certain as I have never seen one for a 999 car. I was only able to determine my car's original color after 8 months of detective work both on line and in paint shops after finding the original color under the weather-stripping and matching it up to paint chips from two different shops records. To sum it up, my car's fender tags have a 999 where the body color code is normally found and the V09 (special order paint), Y14 (sold car), and Y39 (special order) codes are all listed alpha-numerically in the last two lines of codes. Please remember that we have already noticed that where the vinyl roof codes were placed on the tags does vary from plant to plant and that what was done in Los Angeles might not be what was done in Hamtramck.
Y39
26 May 2005 3:09
by rapidtransit
O.K , I have the code listed as - Y39 1969-1971 Special Order.
Thats all it says.
Rapid
19 Jul 2006 20:33
by General
I have a 1974 Ralleye Challenger with:
1st Tag 5th line
999 Special Order Paint Code
A6X9 one piece black
000 Full panel upper door frame
B28 build date
Order #
2nd Fender Tag
V09 Paint Special ORder- I believe it is the Dark Silver Irid A5 or gray which was discontinued in 1974 and had to be special ordered
V6x Black Longitudinal Sport Stripes
Y39 Special Order
26 Radiator I think 26"
L
I do need the build sheet for the car.
19 Jul 2006 22:47
by Alaskan_TA
Broadcast sheets for 999 paint cars just say 999, no mention of the actual color.
T/Ake care,
Barry
20 Jul 2006 8:50
Yeah you really need to find a bit of paint on the car you are sure is original so you can get it matched.
21 Jul 2006 2:48
by JackT
If you do not want to disturb the weatherstripping, you may find the original color on the back of the fender tag or tags - something that hardly ever gets repainted. These got some paint on the line when the inner fender was shot before the second screw went into the tag to hold it down. If so, take the tag to an automotive paint shop and start hunting through chip books. If your 999 paint is not Petty Blue or something easily recognized like that, I suggest you check the C-body color chips for your color - that's where I found my color.
