Page 2 of 2
29 Oct 2004 12:57by Christer
				dave-r wrote: It is very unusual for a 340 package car not to come with all the bits in the package!
NO J54 (Rallye hood) option code!! Very strange indeed.
29 Oct 2004 14:35by aarcuda
				Thank you all very much for helping my out.
Darryl.
30 Oct 2004 19:56by Kevin
				Dave: "Or maybe they couldn't see over the rallye hood? I am 6'1" and cannot see over the hood!"
Yeah, and if you take away his pillow, he is only 5'4" and has to look out through the steering wheel!
Sorry Dave, couldn't resist.  Btw, how do you make other's quotes appear, in that box, in the text of your post?
Kevin
31 Oct 2004 13:26by dave-r
				kcmk wrote:Btw, how do you make other's quotes appear, in that box, in the text of your post?
 Click "Quote" above!
01 Nov 2004 14:43by Kevin
				[quote="dave-r"]Click "Quote" above![/quote]
Hmmm.....
01 Nov 2004 14:44by Kevin
				[quote="dave-r"][quote="kcmk"]Click "Quote" above![/quote]
Grrrrrrrrr !!
01 Nov 2004 15:07by dave-r
				dave-r wrote:kcmk wrote:Click "Quote" above!
Grrrrrrrrr !!
01 Nov 2004 15:09by dave-r
				Well I can't figure out what is going wrong there? It works when I do it! Maybe we are confusing it by using the word quote?
02 Nov 2004 14:29by Kevin
				[quote="dave-r"]Well I can't figure out what is going wrong there? It works when I do it! Maybe we are confusing it by using the word quote?[/quote]
I give up!
02 Nov 2004 15:16by Christer
				kcmk wrote:dave-r wrote:Well I can't figure out what is going wrong there? It works when I do it! Maybe we are confusing it by using the word quote?
I give up!
I have experianced a similar problem myself once or twice, but I am not sure about what it depends on. It seems to happen more often when you do changes in the text between the quotes. I think I have tried to have a space between the text and the "[" or "]". I don´t know if that makes any sence. Other factors: Maybe you have an old operating system or maybe a virus or something???? (Guessing time.....
02 Nov 2004 21:57by jr
				kcmk, you shouldn't check "Disable BBCode in this post" if you want to use BBCode features such as '[quote]'.
Christer, you're right, no extra spaces allowed.
02 Nov 2004 22:07by dave-r
				See. You just needed to ask the right person.
03 Nov 2004 22:12by Kevin
				[quote="jr"]kcmk, you shouldn't check "Disable BBCode in this post" if you want to use BBCode features such as '[quote]'.[/quote]
Enabled BBCode, yet changed text between [ ]'s, still no good.
03 Nov 2004 22:18by Kevin
				kcmk wrote:jr wrote:kcmk, you shouldn't check "Disable BBCode in this post" if you want to use BBCode features such as '
Ok, so I THOUGHT I had BBCode enabled!
   Still doesn't work if you change text, though.  E.g. removing a quote from within a quote.  We ARE making headway.
Kevin
04 Nov 2004 15:22by jr
				kcmk wrote:Ok, so I THOUGHT I had BBCode enabled!
Quoting text where I wrote '[quote]' causes that problem. So simply quoting others quotes should work - as long they don't write [quote] anywhere.
04 Nov 2004 22:09by Christer
				dave-r wrote:Maybe they couldn't see over the rallye hood? I am 6'1" and cannot see over the hood!
I wonder if the T/A hood is even higher? Does anyone of you know this for sure?
Another question that I am thinking of, is if you really can see the right hand side turn indicator (L31 hd/fen mount trn sig ) if you got a T/A hood or a R/T hood?
By the way, I think I have read somewhere that you couldn´t get the L31 option on a 440" or a 426" car. Is this correct?
05 Nov 2004 1:21by Alaskan_TA
				Well, I had to run out and measure since I have both hoods here. It is not easy to get a super accurate measurement because of the curves of the hood, but the T/A scoop at the center is quite close to 3 inches taller than the R/T scoop at the center.
T/As were available with the A01 light package, but the package did not include the L31 fender top turn signal indicators because there was no way for the driver to see the one on  the passenger side. I am not sure about the R/Ts, but it would be darn hard to see it on them too.
T/Ake care,
Barry
14 Nov 2004 10:47by Christer
				Christer wrote:By the way, I think I have read somewhere that you couldn´t get the L31 option on a 440" or a 426" car. Is this correct?
According to Facts and Features, the L31 option (Fender mounted turn signals) wasn´t available for R/T and 340 pkg cars
It would be more logical if you couldn´t get L31 combined with J54 (R/T hood) or N94 (T/A hood), if you ask me.
BTW, thanks, Barry!
14 Nov 2004 19:47by Alaskan_TA
				Yeah, that would have been a simpler way to put it! It is a little odd but L31 was available on Cudas with the Shaker hood and on AARs too. I am not sure about the dual scoop Cuda hood though.
Barry
