1970ChallengerVin#
Postby TimR. » 20 Jul 2001 14:59
Vin#JH2360B141339 Anyone know whats up with the engine code #6 in the vin#?Please tell me its an option code.Thanks Tim Rushton E-Mail-- RushtonT@RBCS.org
TimR.
1970ChallengerVin#
Postby dave-r » 20 Jul 2001 15:27
You sure that is not a 'G' for 318?
1970ChallengerVin#
Postby TimRushton » 27 Jul 2001 19:45
You know it could be.But its not.Maybe I should go on that assumption with this rebuild.Thanks Tim NW.FL.
TimRushton
1970ChallengerVin#
Postby dave-r » 28 Jul 2001 9:15
Sometimes mistakes are made when stamping these things.
You do not say if your car has or had a 318 fitted. If so it should indeed be a 'G'.
1970ChallengerVin#
Postby Christer Nilsson » 23 Aug 2001 9:27
I had the same problem. I my car it looks more like a ´C´ rather than a ´G´.
Tip: Compare the plate on the front inner fender with the plate on the left side of the instrument panel and the plate of the backside of the drivers door. It´s not likely that the text is vague in all these places.
Christer Nilsson
1970ChallengerVin#
Postby Alan (Sean) » 13 Mar 2002 16:52
My sequence # is 307162. Can anybody tell me what number car this is what > I can't figure this out
Alan (Sean)
1970ChallengerVin#
Postby Dave R (Roppa440) » 13 Mar 2002 17:08
I can't quite figure out your sentence Alan. What exactly are you asking?
The sequence number is on the end of the 13 digit VIN. At the start of each year of production after the summer holidays it is reset at each plant to 100001. Then every car coming down the production line gets numbered after that. Each production line had a number of different models coming down it at any one time though. You might have 6 Challengers and then 6 Barracudas. Four door sedans followed by two door hardtops. Each got it's number in turn. So you can't tell from that number how many Challengers were built before yours for example.
Dave R (Roppa440)
1970ChallengerVin#
Postby Alan (Sean) » 14 Mar 2002 14:21
I just wanted to know what that 307162 means in my sequence #
Alan (Sean)
1970ChallengerVin#
Postby Dave R (Roppa440) » 14 Mar 2002 16:12
Oh well. It means yours was the 207,162th car down that production line that model year. I have never seen a sequence number that high before. What is the build date for it and which plant was it?
Dave R (Roppa440)
1970ChallengerVin#
Postby Alan (Sean) » 14 Mar 2002 21:58
To simplify things. The car in question is my new aquisition a 70 T/A. Here is the whole vin if this can help me out.JH23J0B307162
Alan (Sean)
1970ChallengerVin#
Postby Alan (Sean) » 14 Mar 2002 22:03
I would have to get the paperwork out to get the date but I do now the production month date was april 70
Alan (Sean)
1970ChallengerVin#
Postby Alan (Sean) » 14 Mar 2002 22:05
Apri 14 70 is the date I have.
Alan (Sean)
1970ChallengerVin#
Postby Dave R (Roppa440) » 15 Mar 2002 16:21
Don't listen to me. My brain sometimes plays tricks on me. I have plenty of examples of sequence numbers that high from the Hamtramck plant.
Dave R (Roppa440)
1970ChallengerVin#
Postby Alan (Sean) » 16 Mar 2002 14:52
That makes me feel better. LOL
Alan (Sean)
