				ignition key removal
26 Oct 2013 8:41by nzrt
				hi im after some help ,I have just purchased a 70 challenger 4 speed car, and when I turn the key off it only comes back to acc and not all the way so I can get the key out ,is there a trick to get key help needed cheers terry
				Re: ignition key removal
26 Oct 2013 11:08by dave-r
				In the engine bay. Look at the steering column near the bulkhead. There is a lever on the side of the column. That has to be in the correct position so try moving it.
26 Oct 2013 21:12by nzrt
				cool thank you I will check it out cheers
27 Oct 2013 11:14by Adrian Worman
				The release lever on the column hangs up on its mountings sometimes and I have to flick it back with my thumb to get the key out.
27 Oct 2013 15:41by dave-r
				Adrian Worman wrote:The release lever on the column hangs up on its mountings sometimes and I have to flick it back with my thumb to get the key out.
Is this a 4-speed thing?
30 Oct 2013 11:16by fbernard
				I don't remember seeing any kind of linkage between the column and the floor-shifted manual trans (although I have a release mechanism on the column on my 73 cuda).
There was a linkage between column and floor-shifted auto trans originally, which looks like
this.
Obviously, I would think this releases the key only when the shifter is in 'Park'.
18 Mar 2014 5:29by Alaskan_TA
				1970 was the first and only model year for the reverse lockout linkage. If your linkage is intact & properly adjusted, you will have to put the transmission in reverse to remove the key.
This is the same for all 1970 manual transmission cars, 3-speed & 4-speed.
