Those look great! What 's the trick to get the white lettering so clear?
Over the years, the edges of the plastic lettering on both my heater bezel and radio bezel had rounded over from use, so the first thing we did was to square the face of the lettering by carefully block sanding with 600 grit wet-or-dry paper.
Then we "stenciled" the white onto the letters with the following procedure:   First we contact cemented a piece of smooth brown paper to a perfectly flat (jointed) block of wood, using a veneer roller to ensure the paper was fully glued to the block.  Second, we spray bombed the brown paper with a thin coat of white oil-based exterior gloss enamel.  And finally, after the gloss paint had become tackey, we pressed the sprayed paper against the squared lettering, thereby transferring the paint.
For the silver highlighting around the heater bezel letter box, we used a silver paint pencil that we got from an art store, and carefully painted it by hand.  Hope this helps.  I also include a pic of my radio bezel below.
And Jon, by the way, we're in Los Osos, just up the road from you.  Will be looking for your ride.
