				Dash Part 2
23 Sep 2011 12:43by cv70chall
				We completed the dash reassembly and managed to get all the "puzzle pieces" of plastic parts back to where they belong. So far, everything looks good, except the side panel on the driver's side- that does not match up at all to the dash lines.
Could this side panel piece be from a different model year than 70? How can I get these to match up and not look like crud?
				Re: Dash Part 2
24 Sep 2011 15:12by cv70chall
				Is this side corner panel different from 70, 71, 72, 73 and 74? It seems as if there might be some differences in the width of the moulding.
also, were there differences in the dashes between the CUDA and CHALLENGER? I used a dash core form a CUDA and the cap is actually a Challenger cap, so I'm thinking maybe the side panel differs.
Help!
				Re: Dash Part 2
24 Sep 2011 16:13by dave-r
				Cuda is different I am sure. That must be the mistake you have made. There is very few parts the same between the two e-bodies. Windshield and inner fenders are about it.
				Re: Dash Part 2
24 Sep 2011 17:51by cv70chall
				Ok, so I guess that the corner piece is wrong, seeing as the dash cover fit (with some minor sanding).
I'll have to get some measurements of the piece and go from there.
				Re: Dash Part 2
24 Sep 2011 19:31by cv70chall
				Dave-
Can you or anyone give me data on the two different panels? I've looked and can't seem to locate anything- although I obviously need the right part.
If the dash is a cuda, but the cap is a chally- and it fits well- then I must guess that I've got the cuda part and need the chally part, right?
If so, does anyone have a reference part number I can cross-reference?
I'm getting close and hate this little stuff that crops up, you know!
Thanks!!
				Re: Dash Part 2
25 Sep 2011 20:16by dave-r
				Looks like the dash pad and those lower side bits all came as one part number. I can't see a seperate part number for those in the parts manual. The dash pad part number depended on colour and sound system.
But they are different between challenger and barracuda.
				Re: Dash Part 2
26 Sep 2011 13:34by cv70chall
				Dave-
The dash core is actually from a CUDA that had a 3-speaker setup with AC. The cap I installed was a Challenger part and fit fine after some minor foam sanding on the top and side, but 99 percent of it fits fine, so it must be a different side panel.
				Re: Dash Part 2
26 Sep 2011 14:25by dave-r
				Yes. I know.
I thought you were asking if the side bits had different part numbers?
I am saying i looked for part numbers but it looks like the pad and side bits are not listed seperately. The pads themselves all had different part numbers depending on options.
Not sure why you needed a part number. Challenger is Challenger and Cuda is Cuda. But you asked so I looked.
				Re: Dash Part 2
26 Sep 2011 16:15by burdar
				Your side panel is wrong.  You have a 70-74 Cuda/71-74 Challenger side panel on your 1970 dash.
1970-1974 Cuda dash trim is the same for all years.  The 71-74 Challenger trim is the same as the 70-74 Cuda trim.  1970 Challenger is different.
You most likely need to change both the left and right lower dash trim pieces.  I can't see the right hand piece very well in your pictures from the other post but if it came off of the same car, it's probably wrong too.
The 70 Challenger trim doesn't have an accent line on the very front lip of the trim.  The other years do.  Did that make sence?  In your picture you can see the accent line on the front lip.  1970 dash trim is now being repopped but I don't know how it fits.
				Re: Dash Part 2
26 Sep 2011 16:30by Adrian Worman
				I had no idea that the mouldings there were different, in fact I was'nt exactly sure what Chuck wanted, I thought he was having a senior moment
				Re: Dash Part 2
26 Sep 2011 18:24by dave-r
				My parts manual is 70-71 only so does not show the later years. But I didn't see a difference between 70 and 71 in there which does not follow what you are saying. I will have to look again.
				Re: Dash Part 2
26 Sep 2011 19:27by burdar
				Tony's Parts sells the 71-74 Challenger lower dash trim.  There's a good picture of it here.
 http://www.tonysparts.com/newproductsE.htmYou can see the indented accent line on the trim pieces.  I'll try and find the new 1970 parts so you can see the difference.
				Re: Dash Part 2
26 Sep 2011 19:30by burdar
				Here's the company making the 1970 only parts.  Again, I havn't heard if they fit or not.
http://www.motorealm.com/Challenger.htmlYou can see that the 1970 piece doesn't have the accent line on either panel.
				Re: Dash Part 2
26 Sep 2011 20:52by cv70chall
				It's definitely different!
Thank you!!!
				Re: Dash Part 2
27 Sep 2011 20:53by bill70j
				cv70chall wrote:It's definitely different!
Thank you!!!
Here are a few pics of the 1970 Challenger dash trim.  I actually bought the two lower surround pieces from Tony several years ago.
				Re: Dash Part 2
01 Oct 2011 14:53by cv70chall
				I have the correct right side piece, so it's only the left side piece that I'm in search of. Can't seem to find one from anybody- and paying $270 for 2 panels seems a bit expensive.
Yikes!
				Re: Dash Part 2
02 Oct 2011 0:10by bill70j
				cv70chall wrote:I have the correct right side piece, so it's only the left side piece that I'm in search of. Can't seem to find one from anybody- and paying $270 for 2 panels seems a bit expensive.
Yikes!
I may have the left side piece you are looking for.  I'll check tomorrow morning.  If I have it, you'll need to dye or paint it, as it will be the dark blue interior metallic that came with my car. It's yours for the taking if I have it.
Update:  I just checked my parts inventory, and did not find the dash trim pieces.  Must have sold them.
				Re: Dash Part 2
03 Oct 2011 12:56by cv70chall
				BUMMER! I really appreciate your checking for me!
I'll keep searching.
				Re: Dash Part 2
31 Oct 2011 20:46by cv70chall
				I'm still gonna throw it out there-
If anyone has one of these lower left corners, I could really use one!
