I purchased a felt kit from YearOne that makes use of rivets to attach the interior felt to the plastic panels.
The instructions seem clear enough.....place the felt, drill holes thru the panel's "rib", insert rivets with the provided spacer & washer in each hole....
Problem is the spacer does not seem to fit with the TWO layers of "ribs" at the top of my door. Instructions mention only one rib but there are two layers....one is a flimsy rib top of door and the other lower one (lower by 3/8" or so) is the more substiantial rib which seems to be the one I should attach the felt to. Again, the problem is that to fit in the spacer the first, flimsy rib needs to be removed. And, the instructions don't mention more than one rib.
I've seen these used in many cars at car shows, ets so I know they work and are out there.
Has anyone here used this kit? How did you attach this type of felt to the panels?
Thanks
