Moparman1972 wrote:Where does the light that illuminates the glovebox plug into?
red three bullet connector
Does it come out of the glovebox door switch?
switch/light pops into the outside steel frame of the box- light goes in side- light then comes out of a hole with a plactic lens
I assume so, but my glovebox door switch only has one wire coming out of it, and that plugs into the 3 outlet plastic power block.
correct- shell of light is grounded via steel frame
