				Heater box install
12 Mar 2009 23:21by Chris
				Hi, I'm putting the heater box back in my car and since i didnt take it out i'm not sure how it is supported.  Its just the heater no air and the only bolts i can see for support are the three for the blower motor to the firewall. Pictures would be a big help.      Thanks.
12 Mar 2009 23:52by Alaskan_TA
				There is also a "J" bolt, it goes in with the hooked part up. You can see part of it at the right side of this image;
http://www.hamtramck-historical.com/ima ... h%2033.jpg
13 Mar 2009 0:29by Chris
				How does that attach, thats right in the passenger vent inlet right?
13 Mar 2009 2:02by Moparman1972
				That blend-air piece in the article enlightened me. Huh, and here I was thinking I was going to have to get a valve for my heater hose. Turns out I only had a valve for the A/C
13 Mar 2009 17:49by Chris
				I tried to see where that hook could attach and i dont see anything to hook it too and the heater box seems loose with just those three bolts through the firewall at the blower motor.
13 Mar 2009 18:04by Moparman1972
				It looks like it is hooking to a tab on the dash frame?
13 Mar 2009 18:11by Chris
				Maybe the tab is missing from mine because there is nothing close to it. I guess i will have to fabricate some kind of bracket to support it better.
14 Mar 2009 0:10by Chris
				I pulled it out again and found that the j hook was bent down into the vent hole. Of course when i went to bend it back the plastic that supported it broke off. Anyway i fixed it with some metal strips and will try to fit it back in, thanks for the help, heres some pictures of the hook in case someone else needs them.
14 Mar 2009 2:25by Moparman1972
				Doh. Things are never simple....
I will be pulling my dash and heater box next week, so these pictures will be useful, thanks!
