 by Goldenblack440 » 26 Jan 2009 13:55
			Re your dash pad, crashpad - well the term they use in the manual is Trim Pad and it is a PAIN to remove and replace.  I have done both my Challengers.  There are 13 fasteners.  From memory 5 screws (2 on the sides next to doors) and 3 up around the instrument light bar.  All the rest are those speed nuts that are prone to failure after using several times so you have to be very careful with them. You have to be a contortionist to get your head up under there with a lead light or good torch and track them down.  There are a few right at the front around the glove box and the ashtray, also some up around the demister ducts.  The manual shows where they are.  I only have 71 manual- the 70 is slightly different i think. Let me know if you want a blown up pic of the PDF 71 Challenger Trimpad.
