Brant wrote: I'm desperate – Has anyone elso done this themselves? I will not send it out.
thanks guys and happy holidays to all of you.
I have only dealt with one side. The modern reliable way! The solid state conversion was the only option for me. I didnt want to go back inside the dash it just looks to damn good! Also my dash pad is original unrestored and I want to preserve that. But the gentleman wants to know how to "access" the components that make the thing work and does not want to convert anything. He wants to restore it. I think autoinstruments could answer his question more accurately.cv70chall wrote:I understand from talking with the good folks at AutoInstruments that the non-quartz restoration basically lasts about a year or so, and that the Quartz resto lasts up to 10 years.
Anyone else dealt with this on both sides?
I don't have the Rallye clock, only the J21 standard clock.
airfuelEddie wrote:Hey Fabian, hows it going? I recall MoPar Action had an article about the quartz conversion and a couple other electrical "upgrades" maybe their tech archives has the company name. BTW wouldnt a voltmeter measure only potential and not current amount or how much the battery "sees" but not how much is actually needed for re-charging?
airfuelEddie wrote: Nonetheless, I am pretty sure you have to drill out those rivets to access the inner workings of the ralley clock, tach combo. No other way I know of.
Jon wrote:Have you already by passed the amp. meter in another way?
Jon wrote: As for Rt-eng. I have had their tach replacement boards for about a year with no problems. After installing the FBO electronic conversion the tach now reads incorrectly. Don at FBO gave me little help in solving the problem. I e-mailed Greg at Rt-eng and he was all over it. Great support, can't say enough good things about them.
Jon wrote:Fbernard, I don't understand the connection between the battery and the alternator. How is the regulator involved in this circuit? Also, the fuseable link main wire to the bulkhead remains to supply power to the rest of the car?
Thanks
Jon wrote:Found this artical regarding another by pass method. It looks a little rough drilling through the bulk head and such.
http://www.madelectrical.com/electrical ... uges.shtml
Jon wrote:That was not a bypass method. That was the method to beef it up if you wanted to keep the AMP gauge. The part that was drilled through was the bulkhead connector for the wiring harness, this was done because those terminal in there for the AMP gauge tend to get hot and melt the plastic around them. So they just drilled a hole in the connecter and ran a solid peice of wire in there.
I will admit to my lack of knowledge in the electrical dept. but I thought the Amp. gauge was disconnected and the wires soldered together at that location. Did I miss something again.
Yes the bulk head pin connection in this circuit was also by-passed . We all agree this is a "weak link" but, don't we need this source to power the rest of the vehicle?
Thanks
Brant wrote:OK. Here are my results. I purchased some expensive clock cleaner and high grade clock oil. I cleaned everything by injecting the mechenism with the cleaner using an insulin needle. Did this for an hour or so. lubed everything up and ta-da, she works agian.
I then thought I'd test it and hook it up before putting it back in. I hooked it up, it ticked away, the points came together and kicked apart, it ticked away again and on the second touch of the points – she stuck shut and fried the coil.
I packaged it up and sent it out for a conversion. Sure I could have replaced the coil, but for what??? It would just happen again. I tried and I give up.
Please don't look to me for any inspiration, I'm very dissapointed with myself.
   Thanks for the feedback.
