Does anyone have knowledge or a pic on how the arm rests and backing plate bolt up to int. doors? I think I have it but I am unsure of the backing plate. 4 small screws are obvious, but 2 larger ones?? Any help would be appreciated. Thanks.
Are they the two black 1/4" screws? If so they connect the arm rest to the door sheet metal below. So you don't pull the plastic away from the door itself when you close it. Last ones to install after the skin is on the door. (put the lock arm on first though).
