Your right: I had to Dremel a bolt out of the lower assembly arm that runs parrallel to the bottom of the door. Ended up making a slot in the horizontal guide to just get the window out,and the bolt is still on the window with its stupid washer nut:all fused together with rust.... the assembly is still in...six hours labor in all!! By far the toughest disassembly of the car so far
But thanks for all the leg work on the manuals...charging into it has worked up until now....your right:I need my own manual
