I plan to pull my dash soon. I have the manual, but is there anything it doesn't hit? For example, do I need to remove the heater and cables? Also, does the guage cluster come out with it?
Also, where is a good place to mount an aftermarket tach? Right now mine hangs off the bottom of the dash with my aftermarket oil pressure guage, etc. It is therefore hard to see. I have the standard guage cluster. There is a plugged hole where a clock or tach might go. I was thinking of putting this or another small tach there if I can figure out how to attach it. Or if there is a way to put one on top of the dash, I would consider that. Thanks for any ideas!
		 by Duane Phillips (Duane) » 04 Sep 2003 16:27
