Can anyone advise me on how to remove the dash vents that sit inside the dash on my 70. They are the dual outlets above the ash tray and the vent over the glovebox. The silver trim on the adjustable vents needs polishing. Thanks Steve
If they are the same as B bodies, they are held by 4 speed nuts that go onto plastic studs moulded to the vent, pull the tubes off, undo the nuts and lift them out upwards
I think your referring to the ductwork under the dash. I'm referring to the actual grill-type vents that protrude through the dash that you can open and close.
