FRONT DISC-REAR DRUM PROP. VALVE
Postby cv70chall » 02 Aug 2011 18:52
Can anyone post a picture of the correct prop. valve for a front disc/ rear drum setup? I'm hearing so many different answers and want to make sure I have the right part.
Thanks as always!!!
CVchall70
cv70chall
Re: FRONT DISC-REAR DRUM PROP. VALVE
Postby burdar » 04 Aug 2011 14:06
1970 and possibly 71 used a two piece brass valve. The other years used a cast 1 piece unit.
There are some engine compartment pics of a T/A in this link. It doens't show the prop valve very clearly but it may help.
http://board.moparts.org/ubbthreads/sho ... PHPSESSID=
burdar
Postby fal308 » 10 Aug 2011 0:00
Here's pictures of Mopar proportioning valves,scroll dowwn to page 44 http://www.inlinetube.com/PDF%20catalog ... ar-AMC.pdf
fal308
Postby Alaskan_TA » 16 Aug 2011 1:04
Note the date.
1970 brakes 1.jpg (151.96 KiB) Viewed 760 times
Alaskan_TA
Postby Jon » 18 Aug 2011 2:49
I took some pictures while replacing the brake lines a few years ago to help the reinstall . Here is the interconnect between the valves under the master cylinder.
Prop valve connection
1970 Dodge Challenger A66 4-speed.
Jon
Postby cv70chall » 19 Aug 2011 14:16
Thanks! It helped alot! One less step now before we're done.
Install of Valve, Booster and Master Cyl.
CVchall70
cv70chall
