Correct Caliber/ Bracket Colors
Postby cv70chall » 20 Oct 2010 12:58
I'm assembling my front disc brake upgrades for my 70 Challenger and have just finished sand-blasting the parts to get them ready to paint and want to know the correct color they should be.
This project is taking WAAAY longer than I could have ever expected, but it's a learning curve and quite enjoyable!
cv70chall
Postby dave-r » 20 Oct 2010 13:42
Probably just the bare metal finish with a spot of paint from an inspector.
On the drum brakes they painted a rough circle of red paint where it would show through holes in "styled wheels".
Postby burdar » 20 Oct 2010 13:55
The caliper bracket was left bare from the factory. I've been experimenting with different paint finishes to get a factory look. I don't have any pics but can post a link to a thread that was very informative if you like.
Here's what I've done for cast parts that were left bare from the factory. First I blasted them to clean them up. Then I sprayed them with a primer, followed by Rustoleum gloss black. Once the black was on, I misted the part with Eastwoods Spray Gray.(I get "spray gray" and "detail gray" confused...you want to use the darker color) Make sure you just mist it on. You want a little of the black showing through. This gives the part a more realistic look than just spraying the whole thing with the cast color. I took the extra step of very lightly spraying the parts with Krylon Battery Protectant Spray. The battery protectant dried completely just like a paint. I can't really explain what it does to the look but it does add to it. It adds kind of a "flash rust" tint to it kind of. Finally, I spray the parts with matte clear to take away the shine. From a few feet away, it really does look like bare metal.
One more thing about the Battery Protectant Spray. The more coats you put on, the darker it gets. With one light coat, you can see right through it. If you painted your LCA's to look bare metal(Eastwoods detail gray replicates stamped steel) the protectant spray can be used to replicate the cosmoline finish.
burdar
Postby dave-r » 20 Oct 2010 14:52
Damn good tips! :thumbsup: 8)
