When removing the steering column from my '70 challenger, I had my neighbor "mechanic" help me. I went inside and unbolted the bracket to the fire wall. He worked on the steering box and had me hold the column while he hammered on the coupling to the steering box to get it to release from the splines. I re-worked on the steering column after it was out, cleaning it up, repainting it, and checking the wiring and then went to re-install it. It comes up about 3/4" short of reaching the steering box with the coupler.
I was told that this is a 2 piece unit and is designed to collapse in a collision and I may have partially collapsed it. Has anyone else here had this problem or heard of it? Is it possible to "uncollapse" the column to get it to extend and fit? I'm having a bit of a hard time with this one. Your help, as always, is greatly appreciated.
Paul
