disk brakes
Postby moparteenchalleneger » 03 Jun 2009 15:55
my dad just gave me a 1970 dodge cahllenger r/t he through away the front drum brakes but we have a 72 road runner can i just pull the hole k member out from it and put it in the challenger or is it differnt or can i change the nuckels out
Postby ianandjess » 04 Jun 2009 0:07
im no expert but i would expect all parts would interchange except the k frame but if dave or eddie add to this theyll have more idea than me
cheers ian
ianandjess
Postby 72bluNblu » 04 Jun 2009 2:47
The K frame won't swap, the rest of it should. I know the upper control arms and spindles will work, but I'm not 100% on the lower control arms.
72bluNblu
Postby dave-r » 04 Jun 2009 7:33
Yes everything is the same but I am not sure about the K-frame.
Postby dave-r » 04 Jun 2009 7:39
OK. I looked it up.
If it is a 1972 B-body K-frame it is the same so will swap over. If it is a 1973 B-body it will not.
Postby moparteenchalleneger » 04 Jun 2009 14:06
hey thanks guys i think i will be doing it this weekend
Postby Goldenblack440 » 04 Jun 2009 15:04
Would it be easier to just swap the spindles and rotors/ caliperss over onto the existing K frame? If you pull the whole front end out, you'll have to pull the eng/ trans. Unless you hold it up with a crane i suppose. Big job for a weekend! Hope the parts places are open Sunday.
Goldenblack440
Postby dave-r » 04 Jun 2009 15:37
That is what I would do. Unless I needed the LCAs for sway bar mounts and the whole clip looked in better condition with better bushes etc.
Postby Goldenblack440 » 05 Jun 2009 18:25
YEs, or unless they intended to replace the existing setup with the unit all fully rebuilt, bushed and painted etc
Goldenblack440
Postby moparteenchalleneger » 10 Jun 2009 23:17
in rained this weekend so i didnt get it done but neather car has a motor i am geting a 68 383 for the challenger this week but i think i am just goiing to swap the spindles
