Hey hang on! I suggested it first,yes dave has helped me alot with this problem ,he gets alot of kudos for all the help thanks dave
also you have jogged my memorie now, i have 3 shims as i played with alot of different angles,
however i did find 2 other transmission crossmembers from a 72 ,and a 74 e bodie, i found the mounting holes to be in different places on all 3 crossmembers, the 2 later units had the transmission down at a lower angle,so i opened the holes on my unit(the other 2 units were borrowed),and i did manage to get rid of alot of the vibration just by doing that
,i have used 3 different angle finders and its kinda hard to be accurate but i did go by the book and the angle is at about 4 degrees,right with in the 2 to 7 degrees area form that link you posted here,
maybe you can pull that up again to show what im talking about, i think you had some diagram that was really help full,again dave is the knowlegable one here,use his advice cause it helped me
