One more steering box question
How do you detach the steering box from the steering column input shaft?
charliek wrote:How do you detach the steering box from the steering column input shaft?
jh27n0b wrote:Dave, Since you are in England, is that a "right hand drive" steering pin removal tool?
petrodad wrote:fbernard:
You say that the steering column should slide up towards the steering wheel. Are you referring to the lower shaft?
