I'm ready to press in my new lower control arm bushings and pivot shafts and want to make sure I have the process down pat before I start. Do I press the bushings in the control arms first and then press the pivot shafts in the bushings? Or, do I press the pivot shafts into the bushings and then the shaft and bushing into the control arm (I'd use a pipe to push on the flange of the bushing not on the pivot shaft).
Does it make a difference?
