 by Jimiboy » 02 Apr 2008 10:39
			I felt i could show what i did to some wheels that my girl is going to use on her dailydriver... This is aluma, not chrome as your cragars Raven, but i felt it could be fun to show anyway... Maybe it could work as inspiration in some way?
I see there are'nt space enough to my pic's comment's.. If you got "Autosol" In Ireland Raven? Try that with a cotton caster (or other soft material that don't grind the rims) on a machine, it could be worth a shot.
-  They were very worn, and had bumps and damages from schratching pavements(?) and maybe corrosive from the salt we use on the roads during winter...
-  The pic's don't really show how bad they really was, but you get the idea..
-  The first step was to grind the edges of the rim, to even the damages and then work with the whole rim to remove the paint & schratches.. I used grinding discs & machine to even and removing schratches. wire brush to get off the paint.. You can also remo
-  Then when i was done removing dents, schratches and paint, i was using water & sandpaper by hand (400 & 800) (It was lot of work, and this killed my neck and my back, i tell you)
-  The last thing i did was to paint the holes and gapes in grey/silver & polish with metal polishing compound, a product made in Germany, "autosol" i don't know if you got this product in Ireland Raven? But if so, try this and if you like use a machine with
-  I used the same type of caster as when you polish the car...
