Actually this particular point is correct on all classic mid-60s and 70s Chrysler models that I know of. Possibly more.
The bell crank is there to actually reduce the brake pedal force. The power booster needs very little effort to apply the brakes. You would easily lock the brakes up all the time if they hadn't done that.
(Or maybe they just messed up and the power booster would foul the engine valve cover.
If you look at the bulkhead behind the booster you will see that has provision for mounting the master cylinder in two positions. I have mounted this manual MC in the lower position and I had to fabricate a plate to cover the area above where the power version had been.
