This picture is my original spare which has sat in various garages over the past 30 some years. I have never used it but it appears the previous owner had by the slight tread wear. I'm wondering the best approach to restoring it. My thought are as follows
a). Clean it up as best possible and keep as riginal as possible.
b). Touch up the rusted and chipped areas.
c). Sand the entire wheel and repaint. (Though the warning sticker will be lost which is in good shape).
d). Pull the tire and have the entire wheel blasted and powder coated. (Bye, Bye, sticker again)
 Also wondering the what would happen if the tire were to be inflated. Could be problems getting it back in shape or the rubber splitting? If I decided to go the cheaper routes it would be a lot easier to cleanup the  sidewalls fully expanded.
 The car is an occasional driver however, the spare will never be used. Replacement of the tyre is not being considered unless it is destroyed in the process (Heck, I don't even know if a replacement is available).
 All ideas are welcome.
 Thanks
				 by Jon » 13 Dec 2007 18:56
