Hi guys.
I'm installing the Hydratech braking system and it comes with tubes with correct size at hydratech unit ports.
On the other side there is the standard ports of the steering pump and steering box.
I measured the steering pump port and I checked it measure 5/8" SAE, and the nipple on the steering box is fitted with 1/4" SAE inside and shows upside 5 AN male.
Is this correct?
The fittings that comes with the system are female 6 AN and I'm trying to find the correct fittings to build it.
Thanks.
		 by plum-crazy » 24 Sep 2007 22:46
