I'm replacing the brake lines in my factory front disk brake system and had a few questions about these valves. In the first picture on the bottom on the block their is a pin that is spring loaded and can be pulled out. Is this for bleeding the brakes or something? In the back gound is a sender of some sort which has a wire connected to it when in place. Thought it maybe a warning light but I don't think there is one on the dash...
The brass block in the second picture is located on the frame rail just below the driver foot well. The bottom of it has a threaded plug. What would that be for.
Thanks,
Jon
Edit: The pictures didn't load backwards as expected.
