Front brake lines
Postby Challyride » 08 Dec 2006 14:35
Does anyone have a pic or schem. on how the front brake lines trace from the master cylinder to firewall and on down to front brakes? anything would help. Don't want to screw it up. Thanks (Mopar or no car)
Challyride
Board Regular
Postby MLMFLCN » 09 Dec 2006 20:32
Here are a couple pictures before I took mine apart...
MLMFLCN
Postby MLMFLCN » 09 Dec 2006 20:34
...last one was from the mopar nats...but applicable
MLMFLCN
Postby Challyride » 11 Dec 2006 2:08
Thanks alot for the pics, they help alot. (MONC) :D
Challyride
Board Regular
Re: Front brake lines
Postby cv70chall » 02 Aug 2011 21:00
I'm curious. I've got the larger of the 2 pieces I see. I recently upgraded the fronts to disc and will keep drums in the rear.
Do I actually need TWO separate pieces?
CVchall70
cv70chall
Postby MLMFLCN » 03 Aug 2011 14:28
I believe you do. I used an SSBC kit and it came with a proportioning valve. Be sure to change out the master cylinder as well. An all drum car converted to front disc needs the proportioning valve to work properly. I'm no expert, but this is what I found in my research.
MLMFLCN
Postby Adrian Worman » 03 Aug 2011 16:01
The master cylinder on a disc braked car has to have a larger front resevoir to cope with the extra swept volume of the caliper piston.
Jesus built my hot rod
Adrian Worman
Postby fal308 » 09 Aug 2011 23:57
Inline Tube has some drawings that may help. Scroll down to page 15 http://www.inlinetube.com/PDF%20catalog ... ar-AMC.pdf
fal308
