Just reassembling my suspension, pretty much all new parts (PST poly kit)except uca, lca and spindles. The zirc fitting on the inner tie rod ends look like it will rub the torsions. I have not yet put the tires on and loaded the torsions, but the geometry does not look like it will change with a load on the suspension. Any ideas on this? I thought of just filling the inner tie rod with grease, removing the zirc, and then putting a plug in, which would give me more clearance than the zirc fitting.
Also, I did change from .86 to .92 torsions, but that is a pretty negligible increase.
Any help would be appreciated.
