I need help on this one please. I have 72 chall rallye. I noticed a while ago that both my front tyres are severely worn on the outsides. I run 17 inch centerlines on the car. I have looked in the manual and put it down to excessive positive camber problem. At the weekend i found out where you can adjust it. There is two cam bolts, one each side of the upper control arm. I slackened these off and turned bolts, this in turn moved the arm up to straighten the wheel, however you have to guess as when you lower car the weight tends to move wheel back over. It seams impossible to access the cam bolts whilst the wheel is fitted. I turned the cam bolts and tried to position the upper control arm as far back as i can so when the car is dropped the wheel is straight and not lying at an angle. Since i have done this the the wheel is lying to far in now, but looks better. As a guide i am trying to align it best i can to the back wheel . I know there is a spec for this but need to know best way to set this up. Q: Has anyone done this job themselves, if so is there a way, any info greatly appreciated. P.S Does it also affect other components i.e tie rods etc.
