Supports for the rear sway bar ???
Postby SHEETSTER » 31 May 2006 0:08
Anybody out there know where I can get these? Does someboby make them in the aftermarket world? My "74" did not come with them, and I want to upgrade the suspension. I checked a few of the more popular suspension Web sites, and found nothing. I already "rolled the dice" for a used pair of LCA's with the mounting hardware for the bar up front on eBay (hope they are salvageable) and need to complete the equation. Thanks.
SHEETSTER
Postby LITEMUP » 31 May 2006 1:45
i just searched on yearone and they list some for an A body and a B body. if i was a bettin' man...i'd say the B body brackets would work. but i dont know for sure. maybe that'll get u a little bit closer.
LITEMUP
Postby dave-r » 31 May 2006 7:41
Have you tried ESPO? Or PST?
There are two types of rear sway bar. One where the ends bolt to the frame and one were the ends bolt to the axle (the original method). You need to specify which you have.
Postby SHEETSTER » 31 May 2006 22:15
Thanks for the responses. I am looking for the original ones that mount under the axle and lay ontop of the leaf spring. I am going to looking into the "B" body applications as well.
SHEETSTER
