70 Chally steering box #
08 Feb 2006 3:00
by 1152
can someone give me the steering box part number w/ power steering for a 70 Challenger 383 ? you can email me direct if you want @ <bluebugman2@sbcglobal.net>
thx ahead of time
Mike
08 Feb 2006 4:39
#2537397 according to Paul Herd.
(70 Chargers, 70 Barracudas, 70 Coronets, 70 Darts, 70 Satellites and 70 Valiants used the same part number. AAR Cudas and Challenger T/A:s used #2948900)
Re: 70 Chally steering box #
08 Feb 2006 8:25
70 Challenger R/T wrote:you can email me direct if you want
I would rather people didn't do that with information that could be useful to the rest of us. Thanks.
I have an original steering box in storage at home. I will check the number on it.
08 Feb 2006 10:59
by ianandjess
thanks christer
thatll make it easier for me to source parts do you have an expanded veiw of 1 in those books of yours it may help me work out where the play is coming from as mine has a bit of play in the input shaft even when the motor is not running so i figure theres wear in the gears unless its a slack bearing
cheers ian
08 Feb 2006 11:07
Have a search in this section. I am sure I have posted diagrams and adjustment instructions a few times before?
08 Feb 2006 11:10
Just a few weeks ago?
http://challenger.mpoli.fi/forum/viewto ... 2883#22883
Also check out the "sticky" topic on ajustments.
08 Feb 2006 13:26
by ianandjess
cheers dave
it seems that my recipricating ball & worm must be worn ill have to pull it apart & hopefully new ballbearings will improve it enough to get it licensed if not ill have to spend some dough
thanks ian
08 Feb 2006 14:11
There is normally play on the input shaft when the engine is not running. The end play of the worm is adjusted with the end bearing I think and the mesh with the output shaft is adjustable.
Always go right through the full adjustment procedure, including centering the wheel exactly between full lock, before deciding if it needs re-building.
But even when new or re-built they are not great steering boxes.
09 Feb 2006 9:39
by ianandjess
thanks dave ill have a good look this weekend
cheers ian
10 Feb 2006 8:37
Just remembered i was going to check the numbers on my old (original) steering box wasn't I?
I will try to remember this weekend.
