				Tire width
29 Oct 2001 21:02by VON
				what is the maximum tire width I can fit under the stock rear wheel openings assuming I have got the perfect backspacing and all that stuff figured out?
				Tire width
29 Oct 2001 21:11by dave-r
				275mm on an 15" X 8" rim is as far as I would go.
				Tire width
30 Oct 2001 9:01by pete
				A lot depends on getting the Back spacing correct as well.
				Tire width
15 Nov 2001 18:12by EIGHTDOLLARS
				Two questions: what is the backspacing limitations of the challengers? Could a 295/50-15 fit in rear with proper backspacing adjustments?
thanks,
$8
				Tire width
15 Nov 2001 18:25by EIGHTDOLLARS
				Sorry, I read from another post that 295/50-15 is too wide for stock chassis (rear leaf placement). I also like the look of a 17" wheel on the challengers. Any comments?
thanks,
$8
				Tire width
15 Nov 2001 19:01by Christer
				Please, take a look at "Freddies ´74" in the "Photos of your Challengers"-section and tell me what you think of the wheels! 18" high and wide tires. Mmmmmm....
				Tire width
15 Nov 2001 22:20by dave-r
				A 295/50/15 will fit a stock chassis and wheel arch but only if it is squeezed onto a 8" wide wheel rim which is really far too small. Plus you would only have a quarter inch betweem rubber and spring. I don't understand how Freddie gets his wheels and tyres to fit! My 295s only have about 1/2"-3/4" between rubber and spring with 10" wide rims and the springs moved in 3/4". My 15x10 wheels have a 5.5" backspace.
				Tire width
15 Nov 2001 23:33by EIGHTDOLLARS
				I did see that picture of "freddie's." Yeah, 18" looks pretty nice! You'll be paying more for the tires than the wheels at that size, and you have to replace them every...well...(haha).
$8
