Ok guys dont beat me up, i have read most of the posts on wheel sizes, this problem is slightly different. (i hope)
I'm running 15x8 Rallye wheels (aftermarket i guess, i didn't stick them on there) with 4.5"offset and one side clears the top A arm without touching, by not much but it does, the other side a spacer has been fitted and when i remove the spacer it does not clear, it touches, but not by much.
I thought maybe neg camber but its not, its pretty much straight up and down
Ride height measured from the body is equal
I've cranked up he ride height and i can get some clearance although it still touches when the suspension compresses
Does anyone know if the ride height is too low if this causes this type of problem, or shall i just go get me some 15x7's and grind the 8's into small pieces?
