Thanks for the valuable feedback.  Along with offset UCA bushings to help with “sagging frame” I have found tubular control arms designed to help add caster (
http://www.magnumforceracing.com).  I wonder what exactly “sagging frame” is and if maybe subframe connectors can help?
I still don’t fully understand the problem I am faced with and will probably go to a frame shop for a front end disassembly.  Here are some details:
The UCAs are pulled in as far as possible to the midline of the car to get +.5 camber (cams are maxed out).  As it stands would be no way to set a negative camber (I think).
With cams maxed out (to get camber as close to 0 as possible) castor is negative 6 deg, when it should be +1 or so.
I am very confused why the insides of my front tires were wearing fastest when I can not even set a negative camber.  Maybe I do not properly understand all the settings.
Magnumforce offers a tubular UCA that positions the upper ball joint out and to the rear.  Moving the upper ball joint to the rear would help add camber however moving it out would just add more positive camber (if I understand properly).
I guess I really need to go to an expert to find out what is going on.
