has anyone converted to the new plastic master cylinder? im trying it. All of the instalation is fine but i am using the mopar performance proportioning valve and i cant get it to stop leaking for anything. Suggestions?
Also I am changing to DOT 5 brake fluid. Will I be condemed?
Now, I am also taking the power brakes off. My brake pedal will go very far up (towards the seat) so how do i know if i am getting enough stroke out of my pedal. I know i can use the adjustable pushrod to attach the pedal to the master cylinder but dont I still need to make sure i get the correct length of stroke? AND is it possible to over extend the master cylinder? like if the push rod was to long and i pushed all the way down (not forceably at all but...) what would happen?
