A couple of weeks ago I decided to replace my worn out air shocks with a pair of new ones. Took my 73 Challenger into the local shock & muffler shop to have the work done. I have shock extensions on car now. and the air shocks that are suppose to work, the eye hole was to wide to fit into the extension and the shocks were not long enough if I tried to install them by removing the extension. They suggested that I replace the leaf springs (looked original) and put regular shocks on car. So after reading several threads posted on the site here I decided and ordered a pair of ESPO heavy duty leaf springs and a pair of KYB shocks. Well yesterday I had these new parts installed. Leaf springs went on relatively easy, considering I just watched them do all the work, but the shocks were 2 to 3 inches short without the extension, and I have the same proplem with the eye bolt hole being to wide to fit properly inside the extension.
I had to leave the garage to pick up my other Challenger I had at another shop getting the front end aligned and when I returned they had the shocks mounted and the car off the lift and outside the shop. I couldn't get a straight answer on how they got the shocks on, being they were almost 3 inches to short to start with, but it looks as though they sat on the rear of the car to compress the springs to get the shocks on. I have 15" tires on car and needless to say I have no clearance whatsoever and when I drove the car home on some bumps in the road I was getting some tire rub. Here are my many questions that hopefully someone can help me with and sorry about the long drawing out story.
Do I have the wrong Shocks??
Does anyone have the part number for the KYB shocks???
Do they make a longer style shock???
Do they make a different styled extension that will work with the new, what seems to be, wider eye bolt shock???
If so, a name brand or part number and where purchased?
Does anyone recommend machining the thickness on the eye bolt to the size of the old shocks that fit inside the extensions? its about a 1/8" - 1/4" difference.
Last summer on my other 73 Challenger I installed new leaf springs I purchased from Year One, heavy duty ones also. I don't have extensions on those air shocks and I have plenty of tire clearance, although I have 14" tires on this car, but still, I am sitting well above 3" over the tires. I do not see any differences between the 2 cars, except the shock extension on the one. Well I didn't sleep too well last night tossing and turning trying to figure out whats wrong here, but I need to go to work now, so if I don't respond to any answers, I will when I get home. If you need to see a picture of the extensions I can attach one somehow, I think.
Troy
		 by tkdieter440 » 24 Oct 2003 12:32
