 by Dave-R (Roppa440) » 17 Apr 2003 14:04
			You want to remove the "can" above the turn signal switch?
I have described this a few times before so you might want to do a search and see what else comes up but basically you need to make a puller from a bit of thick steel plate that will fit inside the "coffee can". Drill two lage holes in it big enough for two bolts to drop right through that you can screw into the two threaded holes either side of the center. When you tighten them it will pull the "can" up and off the splined shaft.
Of course there is a correct tool to do this but making one is real easy.
