by hans » 04 Jun 2001 9:34
Well, because of the steering problem a couple of months ago I had to change the steering pump. I could get one from a V6 but that one had another pulley then the V8 so I had to change these pulleys. If you're lucky it will come off quit easy. But not always. I could get one of very easy and the other very hard. I had to use an airhammer and the pulleytool? and a lot of patience to get it of. If it won't come of try to use an airhammer while pulling the pulley with that pulley?tool?. I wish you luck and hope it turns out good.
