Drum to Disc Convert for 70 challenger
Postby BigB » 26 Mar 2001 16:53
I currently have power drum brakes on all four. I want to upgrade to disc brakes on the front but I do not want to spend big bucks on a kit. Can I just take parts off of another challenger? if so what parts? I see alot of kits allow you to use the drum spindle and replace the rest out. can I just go and but a pair of 1970 disc brake parts from the spindle out?
thanks
BigB
BigB
Postby dave-r » 27 Mar 2001 9:29
I think the spindles are different on the disc cars. So you will need the spindles, caliper adaptors, calipers, discs, master cylinder from a disc braked donor 1970-72 E-body.
However.
The 1970-72 disc brakes were not that hot. Chrysler was having problems with them. The two piece rotors could warp under heavy use with metalic pads and the inner bearing gave trouble on occasion too.
In 1973-74 they changed the design to a one-piece rotor with a larger inner bearing. I would use those parts if I were you. You can also find the same parts on any 73-76 disc braked A-bodies.
This swap also allows you to use the larger 11.75" rotors if you want but you will have to use 15" wheels with these.
I have put up some scans of this swap as covered in MOPAR ACTION MAGAZINE in another message thread.
I hope this helped some.
Postby BigB » 27 Mar 2001 18:18
thanks for the quick response! i will check around and see if i can get my hands on some 73-74 challenger spindles. so i cant use my power master and booster on the drum system? i will also check in the mopar action mag web site to see if they have old articles posted.
BigB
Postby dave-r » 27 Mar 2001 21:37
You have to change the master cylinder but you can keep the booster if you want.
Postby david pealer » 30 Aug 2001 2:34
can anyone tell me what i need and how to put on the a body disc brakes on my 70 challenger drum car?
david pealer
Postby dave-r » 30 Aug 2001 8:49
Go to the top of this message thread and find the bit where it says;
"The Dodge Challenger Message Board: Technical Area: Wheels/Brakes/Steering/Suspension: Drum to Disc Convert for 70 challenger"
Now click on the part of that title that says "Wheels/Brakes/Steering/Suspension:"
That will take you to the list of threads under that topic. Look for one called "Swap & Stop". That is the one you want. It tells you everything you need to know.
Good luck.
Postby matt » 21 Dec 2001 17:17
Is there anything diffrent for changeing nonpower front drums to power disk. If there is can you tell me thanks.
matt
