				Rear Wheel studs for Minilites
10 Apr 2015 6:13by 70 BeeKeeper
				Greetings from across the pond.
Bought some Minilite wheels for my 70 Bee (tired of the Centerlines) and I am having issues finding studs long enough to mount the rear wheels.  It is a Dana 60 rear.  Stud spline diameter is .660" (approx) wheel hub center is 2 5/8" and axle flange is 3/8" so i need a stud length from under the spline flange to end of thread 3 1/2" .  Wheels have tapered seats for lug nuts.  Can they be removed then the wheel machined for a shoulder nut/washer setup?
Dave???
Thanks eh
				Re: Rear Wheel studs for Minilites
10 Apr 2015 15:53by dave-r
				Your studs should be a half inch diameter?
I didn't have any issues fitting minilites with stock stud length on my Challenger. Are these real Minilites or copies?
				If you do need longer studs have you tried Summit Racing?
11 Apr 2015 4:15by 70 BeeKeeper
				Thanks for the replies folks.
Yes real minilites imported a number of years ago by the guy I bought them from. Summit and all other suppliers which sell Moroso, Milodon as the most common stud manufactures  list their longest stud at 3" once you knock off the "nose" on the stud your down to 2 3/4" of thread which is shy for me.  ARP has some longer NASCAR studs in 5/8" which could fit with a small amount of mod to the wheels.  Was trying to avoid that.
Dave:  Love your ride!!!
1: Are your lug nuts shouldered with a washer or tapered seat?
2: Are your rear wheels 10"?
I will attatch a couple of photots
11 Apr 2015 4:45by fal308
				Have you tried Speedway Motors?
11 Apr 2015 4:45by 70 BeeKeeper
				Rear Wheel Hub Depth
11 Apr 2015 4:48by 70 BeeKeeper
				Mock Up.  Tires ordered. Waiting is the hardest part.........
11 Apr 2015 5:02by 70 BeeKeeper
				fal308 wrote:Have you tried Speedway Motors?
 No.  These guys are great! cant believe I forgot about them. Thanks I will check it out
11 Apr 2015 15:56by dave-r
Standard tapered seat. Standard rear axle. Rear wheels are 10x15.
I had to take them back to the Minilite factory in Telford UK to get the centres of my front wheels enlarged as they didn't fit on the hub of my 11.75" discs.
11 Apr 2015 15:58by dave-r
				Ah. I see the problem. The seat for the nuts on your wheels are not recessed into the wheel!!
The chromed dome nuts on my wheels only just protrude from the face of the wheel. That is your problem.
11 Apr 2015 15:59by dave-r
				Also the hub should sit flush against the drum brake surface.
11 Apr 2015 20:20by 70 BeeKeeper
				dave-r wrote:Ah. I see the problem. The seat for the nuts on your wheels are not recessed into the wheel!!
Right on! Thanks Dave.
13 Apr 2015 10:28by dave-r
				Found a photo of the first trial fit. I think you can just make out the chrome wheel nuts are deep into the wheel. Not sure you have enough meat around yours to recess the nuts and leave room for a 3/4" socket as well?
13 Apr 2015 15:11by dave-r
				The front wheels were only 8x15 with less backspace (4.5-inch). So the wheel nuts didn't need to be recessed as much as the rears with more backspace.
I found this image of one 8x15 front wheel. This was after I had all four centre holes enlarged so the fronts fitted on the big "Cop" disc brakes.
